It is currently Mon Aug 11, 2025 5:14 am
 Post subject: Spruce Density
PostPosted: Fri Feb 23, 2018 6:54 pm
First name: Adam
Last Name: Schultz
City: Calgary
I just finished deflection testing my soundboard. The only benchmark I could find (since this is my first time) was to use 5lbs of weight with the wood supported 18" apart. The idea is to end up with around .25" of deflection. After sanding my top a bit I ended up at .110" thick, which I think is fairly average for sitka? Anyway, just for learning purposes, I measured the density of the soundboard and came up with 479 kg/m3. The wood database website says spruce averages 425 kg/m3. So what I'm wondering is how out to lunch my measurements are? Do you find that spruce used for luthiery is denser than average? It would make sense to me since I've read that with spruce, density tracks fairly evenly with stiffness.
PS. I know that this is way overboard for a beginner builder, so no need to tell me that. I just figured, I have all the stuff for taking these measurements, so why not? It's just one more learning point. The subject of density vs stiffness is of interest to me because I plan on building a mandolin next, and there really can't be many benchmarks for mandolin plates. I'm thinking I can use the density of my mandolin top blank to decide what set of "numbers" I should carve the top to.
 Post subject: Re: Spruce Density
PostPosted: Fri Feb 23, 2018 7:32 pm
That's definitely on the denser side but by no means off the chart. I've had as low as 300 and some slightly above 500.
.110 is bang on factory thickness. So you've got a pretty good starting reference...
PostPosted: Sat Feb 24, 2018 12:14 pm
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
What does your Sitka top weigh at final thickness without braces?
It will probably be alright.
PostPosted: Sat Feb 24, 2018 12:58 pm
First name: Adam
Last Name: Schultz
City: Calgary
It weighs 11.9 oz (.337kg). It is 590mm (23 1/4") by 426mm (16 3/4") The only hinky part is that I cut out the soundhole and installed a single herringbone rosette before measuring it. I put the cutout on the scale with the top, so it kind of depends on how the added weight of the rosette balances out with the spruce removed when I used my 1/4" bit to cut out the soundhole. If anything, I'd say the spruce weighs more than the rosette, but I'm calling it a wash. I was never planning to do any of these measurements or I would have done them all when everything was new and square.
It makes sense if it is a fairly dense piece. When I bought the top I didn't order the high grade, but I called the supplier and asked if he could send me a stiff top even if it had some cosmetic reason he couldn't call it a AAA. I ended up with crazy bearclaw, a kind of cool colour streak and what I think is a fairly stiff top for not too much cash. Since putting a washcoat of shellac on it, I've discovered a little runout in it. This could explain the average stiffness compared to the higher than average density.
PostPosted: Sat Feb 24, 2018 1:09 pm
Stiffness tracks with density with few exceptions. So when you asked for a stiff top in essence you were asking for a heavy top also.
PostPosted: Sat Feb 24, 2018 1:14 pm
First name: Adam
Last Name: Schultz
City: Calgary
Heres a pic
PostPosted: Sat Feb 24, 2018 1:18 pm
First name: Adam
Last Name: Schultz
City: Calgary
I wonder why big factories don't use weight measurements to put different braces on guitars (or maybe they do). Seems like it would be pretty straighforward.
PostPosted: Sat Feb 24, 2018 1:32 pm
There is nothing wrong with dense spruce for tops, if you account for it. It just gives a different timbre.
PostPosted: Sat Feb 24, 2018 2:22 pm
Yes, it's another variable to use in tailoring the guitar to it's intended purpose.
PostPosted: Sat Feb 24, 2018 6:18 pm
Stiffness (or, technically, Young's modulus along the grain) does track density surprisingly well.
A heavier top will tend to be less 'responsive', particularly to a light touch. On the other hand, it will most likely have more 'headroom' than a lighter one.
Users browsing this forum: Colin North, Ken Lewis and 43 guests
